    Apr 2010
    Trinidad
    Hi - I've been using autoGK for months without a hitch but recently something has gone awry with the audio conversion of my MPEG-2 files (TV captures).. for some reason no matter what i do (clean install of codecs, autoGK, removing other apps & codec packs etc) when I do an encode of MPEG-2 --> AVI autoGK will NOT encode my audio no matter what!
    The audio is read from the stream as an "Audio stream 0 MPEG" and no matter whatt option i choose in the advanced options menu (auto, VBR or CBR) the app picks "Original" for the Audio 1 settings ( a wasteful 2 chan 384 kbps MP2 stream)... help!
    I haven't found anyone else having that issue online so far and I did a search here but couldn't find nay similar issues (msot ppl have sync problems it seems).
    Funnily enough I cleaned out my codec packs, and all my encoders, did clean isntalls of
    1. autoGK + full package alone
    2. GK rip & codec packages
    And it still won't work.
    I ca get the compression to MP3 easily using anything else (fairuse wizard 2, GK, handbrake, virtualdubmod - from theautoGK folderr no less) yet once I try to use autoGK it doesnt work.
    Now I know I could sue any of thos eprogs to do what I need to, but I'm used to autoGK and it is MUHC easier for me to queue file conversions using it (I do batches). GK is good if I want complex settings, but takes too long to set up a single encode (I'm doing like seasons of shows)..plus i get great results from autoGK, so i would love if anyone can figure out why my auto GK jsut won't encode audio! The MPEG-2 stream is like 384 kbps and jsut wasting space and reducing my video bitrateusing autoGK as is...
    Thansk for any comments in advance
    EDIT: OK I tried an encode and now I keep getting "EXCEPTION range error" on every encode I try with autoGK - googling seems to tell me this is a codec issue (autoGK can't find a codec..mp3 i'm guessing??). I clean all my packs etc againa dn reinstall only the autoGK package (windows 7). Here is a sample log.:
    [13/04/2010 06:43:37 PM] AutoGK 2.55
    [13/04/2010 06:43:37 PM] OS: Windows Vista (6.0.6002).2
    [13/04/2010 06:43:37 PM] Job started.
    [13/04/2010 06:43:37 PM] Input file: C:\Users\Public\Videos\Recorded TV\intros\Fluffy.Gardens.INTRO.mpg
    [13/04/2010 06:43:37 PM] Output file: C:\Users\Public\Videos\Recorded TV\intros\Fluffy.Gardens.INTRO.avi
    [13/04/2010 06:43:37 PM] Output codec: XviD
    [13/04/2010 06:43:37 PM] Audio 1: Audio Stream 0 MPEG
    [13/04/2010 06:43:37 PM] Subtitles: none
    [13/04/2010 06:43:37 PM] Format: AVI
    [13/04/2010 06:43:37 PM] Target quality: 75%
    [13/04/2010 06:43:37 PM] Custom resolution settings: fixed width of 512 pixels
    [13/04/2010 06:43:37 PM] Audio 1 settings: Original
    [13/04/2010 06:43:37 PM] Standalone support enabled: ESS
    [13/04/2010 06:43:37 PM] Started encoding.
    [13/04/2010 06:43:37 PM] Demuxing and indexing.
    [13/04/2010 06:43:38 PM] Processing file: C:\Users\Public\Videos\Recorded TV\intros\Fluffy.Gardens.INTRO.mpg
    [13/04/2010 06:43:38 PM] Source resolution: 720x480
    [13/04/2010 06:43:38 PM] Found NTSC source.
    [13/04/2010 06:43:38 PM] Source aspect ratio: 4:3
    [13/04/2010 06:43:38 PM] Analyzing source.
    [13/04/2010 06:43:49 PM] Source has percentage of interlacing in motion areas: 53.65
    [13/04/2010 06:43:49 PM] Source has percentage of telecined patterns: 26.23
    [13/04/2010 06:43:49 PM] Source has percentage of progressive patterns: 13.11
    [13/04/2010 06:43:49 PM] Source has percentage of interlaced patterns: 60.66
    [13/04/2010 06:43:49 PM] Source is considered to be hybrid (mostly NTSC).
    [13/04/2010 06:43:49 PM] Looking for optimal hybrid thresholds.
    [13/04/2010 06:43:52 PM] Found threshold of: 0.01
    [13/04/2010 06:43:52 PM] Output will contain 605 frames
    [13/04/2010 06:43:52 PM] Using cartoon mode.
    [13/04/2010 06:43:52 PM] Picking up autocrop parameters.
    [13/04/2010 06:43:52 PM] Running single pass encoding.
    [13/04/2010 06:43:52 PM] Writing the following script to C:\Users\Public\Videos\Recorded TV\intros\agk_tmp\Fluffy.Gardens.INTRO_movie.avs
    LoadPlugin("C:\PROGRA~1\AutoGK\DGMPGDec\DGDecode.dll")
    LoadPlugin("C:\PROGRA~1\AutoGK\filters\autocrop.dl l")
    LoadPlugin("C:\PROGRA~1\AutoGK\filters\decomb.dll" )
    LoadPlugin("C:\PROGRA~1\AutoGK\filters\RemoveGrain SSE3.dll")
    movie = mpeg2source("C:\Users\Public\Videos\Recorded TV\intros\agk_tmp\Fluffy.Gardens.INTRO.d2v")
    cropclip = autocrop(movie,mode=0,wmultof=4,hmultof=4,samples= 10,aspect=0,threshold=34,samplestartframe=0,leftad d=0,rightadd=0,topadd=0,bottomadd=0)
    fixed_aspect = 0.888888888888889
    c_width = width(cropclip)
    c_height = round(height(cropclip) / fixed_aspect)
    input_par = float(c_width)/float(c_height)
    out_width = 512
    out_height = round(float(out_width) / input_par)
    hmod = out_height - (floor(out_height / 16 ) * 16)
    out_height = (hmod > 4) ? (out_height + (16 - hmod)) : (out_height - hmod)
    new_aspect = (float(out_width) / float(out_height)) / fixed_aspect
    Telecide(movie,guide=1,post=2).Decimate(mode=1,thr eshold=0.01)
    autocrop(mode=0,wmultof=4,hmultof=4,samples=10,asp ect=new_aspect,threshold=34,samplestartframe=0,lef tadd=0,rightadd=0,topadd=0,bottomadd=0)
    LanczosResize(out_width,out_height)
    RemoveGrain(mode=2)
    EXCEPTION: Range check error
    [13/04/2010 06:43:52 PM] Job finished. Total time: 14 seconds
    the red bit is my original issue as i'm telling the program to use CBR @ 128 kbps!! Now it can't even encode (blue bit - a reinstall after using ccleaner registry cleaner didn't help)...tearing out my hair here!
    May 2007
    Australia
    I had similar issues with the "Exception: Range Check Error" when I upgraded to Windows 7. The same files would easily encode on XP but not W7. There was a fair amount of discussion on this over at doom9 and it's mentioned in the Autogk FAQ, but I thought it had more to do with setting permissions / running in administrator mode / compatability etc than a clean install?
    Apr 2010
    Trinidad
    Thanks for the suggestion - I checked, and I am running it in admin mode already..plus Vista sp3 compatibility. I wonder if uer defineid setting splay a role which don't seem to be able to be uninstalled..after every reinstall all my choices for the advanced menu are as htey last were... so possibly whatever is causing it to ignore the command to encode MP3 is still there somewhere.
    May 2007
    Australia
    Have you tried granting 'full control' to the autogk folder in explorer (and sub-folders, avisynth - and all that are used by autogk)? From memory...
    Right click folder(s) -> Properties -> Security -> Edit -> Full control.
    Possibly even check/change ownership as well.
    Apr 2010
    Trinidad
    OK - tried that didn't work..as in I'm still getting the new error of EXCEPTION: Range check error
    I might have to try some app that can completely remove codecs as I'm sure the lame codec is messed up. Any suggestions?
    May 2007
    Australia
    Not sure, the thread at doom9 suggested there may have been a certain order to uninstall/re-install.
    Alternatively you could try replacing the lame that comes in the autogk package with something more up to date?
    Apr 2010
    Trinidad
    could try that yep..upgrading teh lame folder in the autoGK directory - and hope it works...
    EDIT: didn't work - I've just about given up and trying handbrake! Will try the Doom9 forum..
    Aug 2006
    I too can't get AutoGK to work since getting Windows 7. I keep getting that same error. I DID have it working, but I had to poke it and now I can't get it to work no matter how many times I uninstall and reinstall everything. Quite close to hurling my computer out the window.
